2018-02-03 8:59 PM
oliverbeirne
‌How to verify that HAL drivers use atomic read modify write operations for multiple instance support?
Do the low-level code call STREX LDREX instructions?
Does the time-out mechanism used to follow the rules of RTOS, for instance, will the timeout mechanism in the APIs of HAL drivers cause the calling task to enter a blocked state until the timeout period expires?
Note: Above question is in reference to the document
UM1725 User manual Description of STM32F4 HAL and LL drivers
Please explain and if possible give the references to the standard documents.
Thank you
Best regards
#rtos #stm32f4-hal-driver #stm32-free-rtos2018-02-05 11:50 AM
The 'CMSIS' layer provides protable names for these things such as osDelay. HAL_delay (or LL_delay) is something specific...
-- pa
