2021-03-31 11:10 AM
Hi everyone!
I am trying to interface my TETRA device with the microcontroller using the USB interface. The microcontroller will act as a usb host while the TETRA will act as a USB device. I am using STM32F469I-DISCO development board.
How can I do such kind of interfacing. Also note , this TETRA device needs a specific USB driver to install and run while connecting with the PC windows. Does the development board can support only those usb devices which don't need a driver run?
2021-03-31 12:11 PM
You'd need to code all the interaction with the device that the driver on the PC side would normally do.
You'll have to pull the Descriptors, and manage the USB End-Points
You'd probably want to get all available information related to interacting with the device from the manufacturer, and look at the bus activity with a bus analyzer to fully understand the interactions and expectations.
