2016-06-07 12:58 AM
I'm working on a STM32F407 Discovery board with CubeMX and AC6 Toolchain and I just started using FreeRTOS in my applications. When I try to generate a project within CubeMX after peripheral setup I get this warning:''It is strongly recommended to use a timebase source other then the SysTick when FreeRTOS is used. The timebase source can be changed from the Pinout tab under SYS''What's the meaning of this warning?Then, if I try to set up a timebase source different from SysTick, I don't know how to configure it. Can someone help me?Thanks. #stm32f4discovery #freertos #tim2016-06-07 1:46 AM
Hi aa.andrea,
I recommend you to have a look to the FreeRTOS middleware configuration view section in the UM1718 user manual.-Syrine -We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
