2023-05-26 4:18 AM
I am trying to develop simple HTTP Web Server using NUCLEO-H745-ZIQ board.
The idea is to have file system to store our HTML web pages.
Do you have an example code to achieve this ? Or else please suggest us a way to have file system to load our html pages using NUCLEO-H745-ZIQ board.
2023-05-31 8:36 AM
Hi @PB S.1,
2023-05-26 7:28 AM
2023-05-30 10:26 AM
Hello @PB S.1,
You can migrate the following example used for NUCLEO-H743 under Projects\NUCLEO-H743ZI\Applications\LwIP
2023-05-31 12:18 AM
Hi @F.Belaid ,
I found an example project under the repository that you have mentioned.
I wanted to know how to generate fsdata_custom.c.
Suppose if I want to add my HTML web files, how to generate fsdata_custom.c corresponding to my web files?
2023-05-31 1:17 AM
Hello again @PB S.1,
To include "fsdata_custom.c" instead of "fsdata.c" for the file system (to prevent changing the file included in CVS) you should set this to 1.
#define HTTPD_USE_CUSTOM_FSDATA 1
You can find this define in lwipopts.h.
2023-05-31 1:47 AM
Hi @F.Belaid ,
I am clear about the inclusion of "fsdata_custom.c" in the project.
But, my question is how to generate code contents inside the file "fsdata_custom.c" corresponding to my custom HTML web file?
2023-05-31 8:36 AM
Hi @PB S.1,
2023-06-01 4:12 AM
Hai @F.Belaid .
Thank you for you response.
Regards,
Prashanth
