STM32F765 and LAN8720A
Hi, the LAN8720A has not the Tx_clk and Rx_Clk signals. Does the STM32F765 supports this configuration supposed I use the LAN8720A in slave mode routing to it the 25MHZ clock generated from the MCU from a ClockOut pin?Thank you.
raffin by Associate III
  • 1661 Views
In CubeMx perspective of IDE after choosing FileX SD interface there is a warning indicating a requirement that a device component class Device, group SDIO, sub HAL needs to be selected in the pinout tab. It is! So why I am I seeing this warning?
 What am I missing?Also I am not thrilled that in the Packs window at the bottom right corner the "Sh..." and "Re..." columns cannot be expanded to see all of what is in those columns, and in the Component Dependencies windows indicates that all cond...
STM32 code documentation locations
Hi. I am currently using the STM32756-EVAL board for some embedded programming. So far, for reference, I am using:PM0253 Programming manual - STM32F7 Series and STM32H7 Series Cortex®-M7 processor programming manualUM1905 - Description of STM32F7 HAL...
OIp.1 by Associate III
  • 3184 Views
Resolved! Calling osDelay from a function called inside a Task
Hello,I have a doubdt and I haven't found the solution on the internet (probably I haven't asked properly or I have been missunderstood)The thing is that I have a peripheral driver,with a function to write and read to and from SPI, and between them, ...
VCasa.3 by Associate II
  • 3681 Views
