ADC DMA Interrupt Not Working STM32L152
Hi, I am working on a project using STM32L152. I have ADC DMA set up as I've used in many other projects using this part. For some reason this time around ADC values are not getting ready by the micro, and when I debug I find the DMA1_Channel1_IRQHan...
EPala.2 by Senior
  • 18191 Views
  • 10 replies
Resolved! Jump to application code STM32F072
I have created a bootloader and application.  My bootloader appears to launch my application successfully; however, the interrupts are not functioning in the application.  I used memcpy to copy the vector table into RAM. Below shows the results of th...
PBaie.1 by Associate II
  • 6307 Views
Fx_NoR_Write_Read_File example for STM32U5x9J-DK
The example does not work. It times out:Stack:HAL_OSPI_AutoPolling() at stm32u5xx_hal_ospi.c:1,831 0x80042e8ospi_memory_reset() at lx_stm32_ospi_driver_glue.c:560 0x8001afelx_stm32_ospi_lowlevel_init() at lx_stm32_ospi_driver_glue.c:79 0x800165alx_st...
efekete by Associate
  • 2385 Views
Resolved! Programming STM32H747AI
Hello,I am currently designing a board with STM32H747AI MCU. May I ask how it is possible to run the RTOS on it and then program it via USB-C without using special internal components such as ST-Link MCU in order to save as much space as possible? Do...
Implementing IWDG in sleep mode
I implemented IWDG  reset having counter of  12 second and am  refreshing it using HAL_IWDG_Refresh(&hiwdg) in while loop.  Everything is working as expected. But now the issue is when I implement sleep mode.  The processor will be in sleep and wakeu...
Nico3 by Senior
  • 4455 Views
