Real bug in the USB CDC
Posted on September 15, 2014 at 14:39USBD_CDC_TransmitPacket() function contains a bug: it sets the 'transmission in progress' flag AFTER starting the actual transmission, so if the 'transmission done' interrupt happens too early, the flag will be ...
ksa by Associate
  • 3996 Views
USB on STm32F411RE
Posted on April 07, 2016 at 11:07Hi,I'm trying to handle a printer via USB with my http://www.st.com/web/en/catalog/tools/PF260320 but I'm facing a problem. Indeed, when my board send the first request for the enumeration, it goes in a waiting time ...
quentin23 by Associate II
  • 2043 Views
2 UART running in FreeRTOS
Posted on April 07, 2016 at 15:11Hi, I use 2 UART ports: UART1 for WiFi and UART4 for debug output. My goal is to send to UART4 data I received on UART1. When I use only 1 UART, it works (UART4), everything I typed on keyboard, returned back. I impl...
UART
Posted on April 02, 2016 at 12:40Hi,I am facing some weird problem in UART.Whenever i am using UART in polling to receive the data followed by storing the data into some array. But what is happening is that the array is sometimes(mostly) starts to f...
bhavesh by Associate II
  • 2512 Views
STM32L0 - DFU support?
Posted on February 21, 2015 at 19:40Hello I just need a confirmation. Is there really no support for firmware upgrade over USB (DFU) in the STM32L0 MCUs??? The STM32L0 is not listed in the http://www.st.com/st-web-ui/static/active/en/resource/techni...
Tantalum by Associate II
  • 1796 Views
Bug when I plug a USB device
Posted on April 01, 2016 at 16:05 Hi, I'm facing trouble when I try to connect a USB device (whatever it is) to my http://www.st.com/web/en/catalog/tools/PF260320. As I plug it, my program is stuck here : Here is a little co...
  • 2375 Views
STM32F107 with LWIP using CubeMX
Posted on March 21, 2016 at 19:59I've created nearly identical projects using CubeMX.First one is using STM32F107, 2 ADCs, ETH. When I compile it and run on my target (EasyMX Pro v7 for STM32 ARM), it gets to main loop without problems.The only diff...
