2022-05-11 6:20 AM
sarathk@sarath:~/Desktop/project/open_s_projects/rust_projects/stm32l/led_blink$ probe-run target/thumbv7em-none-eabihf/debug/led_blink --chip stm32l562qeixq
Error: Error while flashing
Caused by:
0: Something during the interaction with the core went wrong
1: An error with the usage of the probe occured
2: Operation timed out
2022-05-16 7:56 AM
I have connected under reset, it is showing the same issue.
Yes this first time programming the board.
That is I am not sure. When I press reset button LD4, LD5,LD6 and LD7 glows in sequence and stops. Finally the LD9, LD10 and LD5 are on.
2022-05-18 7:39 PM
Hi, still I am not able to figure out the issue , Can you please help me. Thank you.
2022-05-19 1:52 AM
Hi @bsara.1 ,
Try the tips provided in the article How to solve debugger connection issues?
May be you altered debug pins with your first loaded code.
-Amel
2022-05-20 6:22 PM
Mode: Under reset
Reset mode: Hardware reset
