2021-12-19 9:56 AM
2021-12-19 10:38 AM
Seems entirely unrelated to the VBAT pin.
What did you do with the BOOT0 pin? Where did you locate your code?
2021-12-20 6:06 AM
Thank you for your attention. I disregard this pin!!! In this application this pin I left open. Can I solve this problem programming the FLASH_OPT register? I don´t know how to change this value inside STM32Cube_IDE. Do you have some advice?
Thank you again,
Best regards, Ilson
2021-12-20 6:36 AM
Possibly, you're in the best position to test these things for yourself.
You should be able to check and change these settings from within your own code, or configure via STM32 Cube Programmer.
CubeIDE, not sure, not my tool.
