2020-11-07 6:35 AM
How can I solve this problem.If I earse mychip maybe I can solve but I dont know how can ı do
2020-11-07 8:29 AM
Probably because you have reconfigured the GPIOA pins used by the debugger. ie a blind write into configuration registers, breaking PA13/PA14
To erase, select "connect under reset" option for tools, or strap BOOT0 High so it doesn't run your code.
2020-11-07 11:06 AM
when I debug my code ,at debugger options ,reset behaviour is 'connect under reset' but it doesnt work
2020-11-07 11:31 AM
It won't matter what setting you have if you disconnect the pins the debugger is using while it is running.
Look critically at your code
2020-11-07 12:39 PM
I understand you but in my board, boot0 pin is PA14 but I dont se on the board PA14
2020-11-11 4:51 AM
Looks like the problem is solved, but in a community like this one, how you solved it is always interesting to other users.
When your question is answered, please close this topic by choosing Select as Best.
/Peter
