2023-05-15 7:13 AM
Hi everyone,
I'm trying to program a pcb which has STM on it as MCU. Using Nucleo board Stlink but it gives error.
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target
2023-05-15 8:00 AM
Hello @Mine ÇETİNKAYA ,
It could be damaged, issues with power supply, or not wired up correctly.
If NRST pin is connected you can use "connect under reset" to try an wrestle control.
Use STM32 Cube Programmer
Foued
2023-05-15 8:00 AM
Foued
2023-05-16 1:34 AM
Thank you for your reply,
It was about power, I forgot to supply power for PCB. Now, It works!
Thanx a lot again,
Mine
