2024-10-11 3:32 PM - last edited on 2024-10-14 8:38 AM by mƎALLEm
Greetings.
I have a project I developed on ESP32 (CH340 Chip). For some reasons, the project got messy, and I would like to migrate to a new board. I have an STM32 Nucleo which gave me a lot of satisfaction, but for this project I need something
-Small
-Wifi Capable
-With at least a dozen ports (PWM, NFC, Analog etc)
-That supports protocols for talking with Siri/Alexa/GNest (I bet this is on libraries)
-Can run an Http server
-Economic wouldn't be bad.
I was thinking something like the BluePill, but there isn't any version with buitl-in wifi. My environment for development shall be Keil Studio. An you suggest something?
Thank you a lot for the attention
Marco
2024-10-14 8:24 AM - edited 2024-10-14 8:24 AM
Hello @MMast.11 ,
I may suggest B-L475E-IOT01A Disco board.
It has WiFi, PWM analog ..
That something you need to integrate by yourself. See also this link.
@MMast.11 wrote:
NFC
NFC GitHub example on that board: https://github.com/STMicroelectronics/STM32CubeL4/tree/master/Projects/B-L4S5I-IOT01A/Applications/NFC
Hope it helps
2024-10-14 4:12 AM
Hello Marco,
You can use ST-MCU-FINDER tool to fine-tune your choice of STM32 MCU and select the suitable one that will fit your needs, I recommend considering the STM32WB series MCU: STM32WB Series Overview
Hello @MMast.11 ,
@MMast.11 wrote:
NFC
Hope it helps
2024-10-14 2:17 PM
Yes, the STM32WB seems to be a possible solution. It doesn't have Wifi, but I think it will be fine.
2024-10-14 2:19 PM
Yes, this is good. It has everything I need. Unfortunately is more expensive and bigger than of what me and my colleagues are looking for, but this REALLY seems a promising solution.
2024-10-14 2:21 PM
Thank you all, I really appreciate your time. I will bring this solutions to my team, and they will decide. Both seems good to me. I will wait a couple of days to see if someone else would like to add something, and then I willm ark this as solved.
