2018-01-09 8:42 AM
I am trying to change the settings on the STM32 ST-Link Utility, jhowever, the software seems to be freezing. I also installed it on another computer and it still doesn't seem to work. The problem is shown in the attached screen shot. Any suggestions as to why?
#st-link-v2 #stm32-st-link-utility #st-link-utility-problemSolved! Go to Solution.
2018-04-15 4:34 AM
Check if the target chip has all pins properly soldered (especially grounds and supply, including the analog ones) and that there is no short between the signals and any other neighbouring pin or track.
Use a short cable between STLink and the target (<10cm).
