Resolved! How to connect ST-LINK/V2 ISOL
Posted on October 03, 2017 at 08:58I'm trying to connect new ISOL version debugger to a device I have been debugging with the old ST-LINK. I do not have 20-pin JTAG on my device (small battery operated STM32L100) and I try to get only 3V3, GND, SWDI...
Resolved! Can not set "nBOOT_SEL" bit in STM32L011F4 MCU.
Hello, everybody.I am developing one small application, using STM32L011F4 MCU. As I realised from datasheet, there are two ways to boot from flash memory:1)Connect PB9-BOOT0 pin to ground;2)Set nBOOT_SEL bit and use nBOOT0 bit instead of BOOT0 pin. A...
MPisk by Associate
  • 2560 Views
technical support for PCB Design
Hi sir,        I have used STM32F746BGT6 Controller for our New Project.I have used 7 & 4.3 Inch display Ethernet, SDRAM & Flash.we need the tecnical support for PCB Design.could you please help me.Regards,         M. Maha
MMAHA by Associate
  • 1068 Views
Resolved! How to upgrade the STLinkUpgrade app.
My version of STM32CubeIDE is Version: 1.0.2 Build: 3566_20190716-0927 (UTC)The STLinkUpgrade app is 3.2.11. It says that the last firmware version is V2J31M21. However the latest version of ST-LINK/V2-1 firmware (V2J34M25))? One can use the standalo...
JFlesher by Associate
  • 1859 Views
Pre-sales question about STM32H750B-DK
I note that the ​STM32H750B-DK comes with an attached display. If required for evaluation / development, can a larger display be connected in its place? Something in the 8" to 10" range. Touch is not needed. If so, can you recommend any brands and/or...
DLoye by Associate
  • 973 Views
