Resolved! Nucleo-H755ZI Configure Power Supply
For the Nucleo-H755ZI, I use the 'PWR_DIRECT_SMPS_SUPPLY' choice in 'HAL_PWREx_ConfigSupply', like: HAL_PWREx_ConfigSupply(PWR_DIRECT_SMPS_SUPPLY); With this setting, the board works fine and keeps working after flashing.If you choose for example 'PW...
Jack3 by Senior III
  • 4450 Views
Eval Board ADXL354
Hey everyone, I am working with the ADXL 354 eval board with an STM32H745data sheet ADXL354 : https://www.analog.com/media/en/technical-documentation/data-sheets/adxl354_adxl355.pdfdata sheet eval boad: https://www.analog.com/media/en/technical-docum...
fru999 by Associate III
  • 1890 Views
STM32h745 ADXL355
Hi everyonethis is my code for reading X axis ADXL355 accelerometer thanks to STM32h745.But when I run it, i keep being stuck if the HAL-SPIèTransmitReceive Can you help me ?
  • 2211 Views
UART on STLINK-V3MINI
Hi,I'm using a STLINK-V3MINI with fw: V3J12M3 STM32 Debug+VCP, and there is an issue that i'm not sure if it is by design or a bug.In my design I have SWD and UART pins in separated connectors (both with GND). When the SWD is attached to the CPU, the...
mscaff by Associate II
  • 2950 Views
