2019-05-09 11:54 PM
First of all I am very new to application development with ST-Electronic device shields.
I have following devices with me,
X-NUCLEO-NFC05A1 - NFC expansion shield
Nucleo 64 : F401RE board.
I was doing some samples with ARM Mbed online compiler.
I want to access external NFC tag's content via NFC05A1 expansion board in ARM Mbed. However, I was not able to find a correct library for NFC05A1 expansion board in ARM Mbed. But, I found a sample and a library for different version of NFC shield : https://os.mbed.com/components/X-NUCLEO-NFC01A1/ and this is not compatible with the NFC05A1.
I was wondering whether there is a library which I can use in ARM Mbed to access NFC functionality in X-NUCLEO-NFC05A1 board.
Note: I found a following CUBE sample for this expansion board but, I do not think this can be used in ARM Mbed as a library.
2019-05-21 3:51 AM
unfortunately we don't provide an mbed version. However the X-CUBE-NFC5 contains the so-called RFAL (RF Abstraction Layer) which is written with portability in mind.
BR, Ulysses
2019-05-21 3:51 AM
BR, Ulysses
