2021-12-21 2:42 AM
Hi, I am designing an application using the SPV1050. I am not using the LDO function, and am only using the SPV1050 for charging my battery.
I have tied LDO1_EN and LDO2_EN to ground. Can I safely ground the LDO1 and LDO2 pins as well in this configuration, or must they stay floating? Having them grounded would help the ground plane.
Thanks in advance
