2011-09-07 1:11 AM
Hi gentlemen
I'm planning to use L6207 PD for 2 brushed D.C motors, does any body know whether is it possible to use n.c. pins close the outputs to increase the path's width or they must be left unconnected. I'm quite surprise only one pin is used to deliver 2.8 RMS Amps, and data sheet is'nt so clear about that. Thanks for suggestions2011-09-09 12:05 AM
the 2.8Arms are indeed guaranteed from only one pin. About the n.c. pins, it's a good idea to connect them to ground plane so as to facilitate heat dissipation. Regards, Billino2011-09-09 2:21 AM
