2024-06-24 7:35 AM - last edited on 2024-06-24 9:24 AM by Peter BENSCH
I am using L978s sensor with SPI communication. Frame count bit should be toggling in every frames while receiving. I transfer first frame 0x5280001F to read STATUS5 register. I get response as 0x40800021. I send second frame by toggling frame count and updating CRC. But I get same response 0x40800021. The response from the chip always have frame count 1. It is supposed to toggle. Not seeing any communication error being set in the response.
Can you please support to find the cause of this error?
Thanks in advance.
2024-06-24 9:21 AM
Welcome @Sandrakyr, to the community!
the L978S is a customised device for which only the customer placing the order has data and documentation and receives support; the public community cannot help you here.
Please contact your local ST contact person or the online support OLS.
Good luck!
/Peter
2024-06-24 9:21 AM
Good luck!
/Peter
2024-07-01 9:12 PM
Ok, thank you.
