2023-01-05 9:42 AM
Hello Everybody,
i would like to design my first PD Board using the STUSB4700 IC. Since i´m quite new to PD IC´s i thought it would be best practice to just follow the typical use case: "Power supply - buck topology" as seen in the datasheet. While replicating that schematic i ran into some problems.
also if someone could also have a brief look over my current schematic, to spot any mistakes, that would be really awsome!
thank you in advance and kind regards from austria
DaJunti
Datasheets:
