Power management
Hi all, We are new here. We are thinking of using ST L6203 motor drivers on our robots and are wondering if it is recommend to control motor speed by PWN on the enable pin or is better to PWN either IN1 or IN2 depending on direction.
http://users.ece.utexas.edu/~valvano/Datasheets/L6203.pdf We've had quiet a discussion about this and it would be great to know which method is preferred.CheersTerry
TSmit by Associate
  • 1012 Views
Opto-coupler for L6470 ?
Posted on May 21, 2018 at 16:33It is necessary to apply a opto-coupler between an SPI Master and the L6470 circuit on the X-NUCLEO-IHM02A1 board ? I could not find any information about galvanic isolation in L6470 documentation.#x-nucleo-ihm02a1 #op...
Driver selection for High Power LEDs
I'm currently working in a project where I need to control the intensity of 24 high power LEDs in 5 levels. I'm planning to use LumiLeds L1CU-BLU1000000000 (https://www.lumileds.com/uploads/705/PB198-pdf) where the cut-off voltage is 2.83 volts and c...
RMeno by Associate
  • 890 Views
L6482, BEMF spikes
Hi,I'm using L6482 Stepper motor driver and I'm capturing BEMF spikes that can be up to +/-17V above VS and GND.It been measure at the OUT1A to GND.Is it acceptable? It is not clear in datasheet.Also I don't see any protection devices requirement su...
