Power management
How to use battery on B-L072Z-LRWAN1?
I found jumper jp9 for section TCXO to VDD or extrnal TCXO power but not sure set mode to use battery holder BT1. Please advise me. How to use battery on B-L072Z-LRWAN1.
SPrap by Associate
  • 603 Views
SPV1050 behavior after UVP threshold
Hello,I would like to know what supposed to happen after the UVP threshold.During my test, I put a load at the LDO2 output and after the UVP threshold (Vbatt at 3.7V) I removed the load. After that, I put a solar pannel on Vin. I don't know why but t...
Issue with starting VIPer35 flyback
I'm facing a strange situation with VIPer35. First, I bought STEVAL-ISA183V1 evaluation board to got an idea how VIPer35 works. Then I made my first prototype PCB using custom made transformer that also works fine. But when I use the same schematic (...
DKotl by Associate
  • 868 Views
STPM34 Active Power and Power Consumption Issues
Hi guys,I'm using STPM34 ASSP IC and get some issues. Hope you can give me a help. I followed it documents and recommend design.I’m trying to use your evaluation firmware in order to interfaces with STPM34 by using an external MCU (STM32F15) through ...
TLe.11 by Associate
  • 948 Views
BLDC Error FOC with ST Motor Control Workbench
Greeting!First of all I'm quite new and not really familiar with the STM products.I want to control a BLDC motor (Turnigy Multistar 4225-390Kv 16Pole) with the Steval-spin3201.When I connect the ST MotorControl Workbench with the eval-board and press...
tom1 by Associate
  • 953 Views
