Power management
Resolved! Controller for dual encoder and 100kHz PWM brushless motor
Hi,I"m starting new project with brushless motor and I would like to connect two encoders (Rotary and Linear) with 3 hall affects and current measurement.I would like to check which ST controller "strong "enough for the applicationfollowing the param...
Lkr.1 by Associate II
  • 2662 Views
B-g431b-esc1 vs steval-esc001v1
Hello all, I would like to understand the key differences between the two controllers and which one would better suit my needs. ​I want to precisely control the speed of two sensorless bldc motors, keeping them in sync regardless of the load each of ...
Hannibal by Associate
  • 810 Views
Resolved! Using STEF01 as a high-side switch
Hi,I'm planning to use STEF01 as a high-side switch plus an external MOSFET for blocking inverse current from load. Is this feasible or I would be wrong?gaston
Gaston by Senior
  • 1169 Views
Resolved! ALED6001 eDesign dimming setting
Hi Sir,​ALED6001 eDesign show BJT is as the red rectangle.However, most PNP BJT is show as below picture.I search some data, they show exchanging BJT's E and C, BJT can work. However, the hfe will decrease and the BJT cannot afford high voltage.Below...
TSU.11 by Associate II
  • 1212 Views
Resolved! L6482 step-clock mode
Hello,I am designing a stepper motor controller with L6482.The choice of L6482 was made because of its integrated dual h-bridge gate drivers and relatively high voltage rating.The chip features nice set of motion commands but due to specific demands ...
PKrak.1 by Associate
  • 1575 Views
