Resolved! Implement s-ramp on stepper
Hi, I need to implement an s-ramp for a stepper motor.Currently using L6482.Can you please point me in the direction of the correct controller + driver? Thanks!Uri
Hi all,I'm using L6482H stepper.The need has arisen to drive 2 motors simultaneously, with the same profile.I was thinking about daisy chaining the SYNC output of the first driver with the STCK of the second driver. But I understand that this will n...
I am using STC3100 Battery monitor IC with Coulomb counter/gas gauge IC for measuring by 2500mAh Li-ion battery capacity over I2C interface with my Nordic NRF52 BLE SOC chip . I have followed the reference design which is provided in the datasheet ( ...
As I understand it, to initiate soft switching, the MOSFET devices need to be switched when the resonant current passes through zero. How does the L6599 know when to do this?Cheers & thanks,DG
we have 2 STM labels for STN3P6F6, which PBT difference, 260 C and 210 C, would you help to check what is difference or STM has PCN to changed this information, thanks,
ST Motor Control Worbench example reference MAGTEC motor but doesn't state type.Does anybody have suggestions for an affordable test motor to use with this kit ?PMSM15-20kW 1500-2000rpm5 polepairs560VDC (bus voltage)Encoder
Hi,Is it possible to force STUSB4500 to operate at 15V using only hardware solution and don't require any NVM programming? Thank you
