Diode SMB pack body marking "6T C409" is used in protection circuit. Wats to its complete part number
Trace code for STD100N107F7 our IQC team would like to know that why the trace code is different between label and component Text , please see the attachedand also could you please let me know the date code of this batch .Thank you so much
hii do you have evaluation board for L9935Two-Phase Stepper Motor Driver
Hi ST,I could find pdf format of those files under CAD Resources but can't find gerbers and schematic project files.If they are available, how can I get those files?Thank you.
On Page 8 Chapter 4 Electrical Characteristics, the Value IIN says on Shutdown mode with RPRG = 24kOhm is typically 60uA. This is quite a lot! Does this current also flow when the charging adapter is not connected anymore, meaning Vin = 0V ?
