VN5T006ASPTR-E Date Code
Please help to share any docs showing date code in the top marking for the part number VN5T006ASPTR-E. The marking "209" denotes DC 2209 whist marking 101 denotes DC 2101. Please refer to attached photo for reference. Thank
I have a STEVAL-IPM05F. My goal is to switch on/off the IGBTs. While I try that, I got many difficulties, like loading the Boots voltage etc. Now I have four questions. Why are all of the bootstrap capacitors carched although I don't switch the LOW-S...
we have bought a batch of L297/1, and found the appearance has shown very bad surface plating result. we have bulk ID on the outer box, please help to confirm if the parts are authentic from STM.[edit: some information removed by moderator] thank you...
1/At present, the most important problem is that after activating IN (input effective power supply), turning off SD (high level), and operating for many times, LDO has voltage output when IN is activated and has input all the time. Once IN has no inp...
Hello,I would like to know how to add analog dimming (1-10V) to a HVLED001A based LED driver.Regards,
Hi everyone,I recently purchased the B-G431B-ESC1 kit. I did a sensorless experiment with the ST motor control workbanch and it worked as expected. However, when I want to test with the encoder, the rotor remains locked and does not rotate after alig...
Im not sure how to figure out the value of the bootstrap cap. Because I want to drive mosfet with 400kHz (I want to use it in a audio application) and the bootstrap diode is rated with typically 140ohm in datasheet. Problem: I see the mosfet charge i...
Hi,I am designing a BMS exploiting the L9963E ic. The battery pack is a 144V one, made of several lipo cells in series. I'm going for a Distributed configuration, using a master board and 3 slave PCBs. The question is:The VBAT pin cannot support volt...
