Power management
E-L9823013TR
Hello!I would like to clarify, can I use octal low-side driver E-L9823013TR in daisy chain SPI configuration?Regards, Val
Valeryi by Associate
  • 881 Views
Alternative of LDFM50DT-TR LDO
Hi, In my current design, I am using LDFM50DT-TR LDO for 5V output which acts as a source for RFID transceiver circuitry. LDFM50DT-TR is preceded by MEV3S0505SC (Digikey link) whose output goes to LDFM50DT-TR, please check the attached image for more...
spice model for STN4NF20L pin ordering
Looking at the ST spice model for  STN4NF20L i see only .SUBCKT STN4NF20L 1 2 3 There is no text note in the spice model file as to what the assumed pin ordering may be. The nodes in the model have no helpful names like DRAIN GATE SOURCE. Yes I can f...
3 core flexible / rubber cable
Hi, I am looking for some very flexible 3 core cable for my soldering iron. The stock one on the soldering is very rigged. Heat proof and all that good stuff, tangle free as well. Thank you
L4986A model for Simplis/Simetrix compatible for POP Analysis
I am working on a project using L4986A. I was trying to get a bode plot of a boost PFC using L4986A model on simplis but I could not do a Periodic Operating Point (POP) analysis due to the IC containing non-linear blocks.I am wondering if there is a ...
J_tomi by Associate
  • 1489 Views
