GateDrive problem for motor control
Hello, I am using a circuit for motor control. comment but sometimes it lights up, I think it's a hardware problem. Can you examine the circuit?
Dear all,can i get ic datasheet with pn gnzb208
I have bought an STEVAL-PCC009V2 interface board that I want to use to drive an EVAL6472 stepper motor driver evaluation board but when I connect it to my Laptop Running Windows 10, it prompts me to update the firmware to the latest version 2.7 Firmw...
We need the schematics to eb checked for 10W power output
Hello I am trying to use library provided by your site to A5975AD - dcdc conventer.Unfortunately when i try to run simulation it pop out notification that some nodes are wrong defined.You have encrypted library and manual to use this library is only ...
Hi, STM professors: I'm looking for the products that using the TAPERED OXIDE tech shown in the Figure. Would u please show me some? Thanks! Sincerely.
Hi team, Kindly assist us with below mentioned queries. For the part series ST890DTR Datasheet did not specify junction-case thermal resistance and junction-board thermal resistance. we need these values for the thermal simulation. so, can you pleas...
HelloI have a question regarding SOA of STD18NF25.How should we consider derating when Ta=100℃?What is the calculation method if there is no graph for [Power Dissipation Derating Curve]?MOSFET is used as a low side switch.Each voltage and current con...
We have purchased L9301 evaluation Board alone,now i need to test the board with #configuration1 , is it possible to test the EVM board without external controller ?
