2017-01-26 7:50 AM
I've adapted UART_Printf example to use ITM_SendChar. No output is seen in Eclipse (SW4STM32). I've verified (debugging) that ITM_SendChar is really called. Is it possible to use ITM with this board (Nucleo-F767ZI, 144 pins) and IDE? Are there any soldering bridges required?
#debug #eclipse #nucleo-f767zi #sw4stm32 #trace #itm #nucleo2017-01-26 9:05 AM
Hello
I have moved your thread to the
‌ where someone should be able to assist you.Thanks
Oli
