2022-12-18 9:55 PM
I am facing problem Teseo-LIV3F is not sending out any NMEA messages and also not accept any commands. Anyone know Why? and How to set back to "Factory Setting" ?
2022-12-19 12:38 AM
what if the Teseo is working but your uart config is wrong?
If i were you i would stick an oscillocope/logic analizer on those RX/TX traces
2022-12-19 1:21 AM
I sticked an oscillocope/logic on Pin2(UART_TX) but I could not see any signal coming out.
Before I sent command to change uart baurate to 38400 i received NMEA messages from Pin2.
Do you have any idea what happpened with uart config?
The command I send to change baurate is: PSTMCFGPORT,0,0,1,38400
2022-12-20 12:17 AM
What if you try to do a FW update or recovery?
