2015-12-10 5:06 AM
2015-12-14 12:45 AM
Hi Franz,
Have a look at the option bytes specifically the AFR bits. Hope that helps. Ian2015-12-17 6:31 AM
Thank you IAN
I found the AFR2 bit in the small documentation of uP Here the instruction for all with same problem: ST Visual Develop --> Tools --> Programmer --> Option Byte --> set option with right mouse button Register Program Start must be pressed. Finish and it works. Franz2016-02-21 11:18 PM
