2003-06-27 12:47 AM
ST92F150 electrical characteristics - I2C
2011-05-17 2:34 AM
I have some problems with ST92F150 electrical characteristics for IOs Schmitt trigger (vih,vil,hyst), especially for I2C. For me, Hyst = Vih - Vil, but ST9 specs do not fit with this equation. Could anyone clarify this point ? I want to drive a 3.3V ST I2C EEPROM using ST92F150 (5V) and I need to know how to connect components . Are external pull-ups to 3.3V only required ? (Is ST92F150 I2C peripheral compatible with 3.3V parts ?) Thanks2011-05-17 2:34 AM
Have alook at the phillips I2C bus spec, it gives you info about level translation at the end of the doc using fets.
I have attached if you do not have it. Regards Spen2011-05-17 2:34 AM
Spen,
Thanks for the I2C specs. But my question is more simple : Is ST92F150 (5V) work with 3.3V devices with only 3.3V pull-ups on SDA and SCL lines ? fred.2011-05-17 2:34 AM
Spen,
I found information I need in I2C specs you sent me. Thanks. Fred.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
