st9
caterina_lelli
Associate II
Posted on July 28, 2003 at 07:05
st9
5 REPLIES 5
caterina_lelli
Associate II
Posted on May 17, 2011 at 11:34
I 'm having troubles with the microcontroller ST90T40C6. Is there any difference between the ST90T40C6 and the ST90T40ZC6?
The same program and circuit works fine with the second but the first don't even start
thank you
Catia
romain2399
Associate II
The ST90T40ZC6 microcontroller has been shrinked from 1.5µ to
1.2µ technology, becoming ST90T40C6. They should be compatible.
Please, give more details.
caterina_lelli
Associate II
Maybe there is a difference in the reset circuit because if I force a reset the microcontroller ST90T40C6 starts working again.It just don't start when I give tension
romain2399
Associate II
Do you use a Low Voltage Detector to keep the device reset while the power is not at the good level ?
bertrand23
Associate II
Please check attached files. Hoepfuly it can help you solve your problem.
