2004-01-09 9:34 AM
ST7FLITE10 programming tool, any available??
2004-01-09 5:57 AM
HI!
Any working, available tools for programming ST7FLITE10? Must be compatable with the model ''10'' for this device family. None on the web mention useablility with this device. Only ST7FLITE15 or *19 mentioned.2004-01-09 6:04 AM
No problem, the FLite10 is supported by the same programming tools (ST7 MDT10-EPB, ST7-STICK...) as the FLite15 and FLite19.
Download the latest version of the ST7 Visual Programmer, v 1.9.1 , .2004-01-09 7:11 AM
Thanks jugnon.
I downloaded as you mention, and suspected as such. But, I am actually looking for a portable device, like the units from Segger (Flasher) or a Key Fob (Kanda) type units. Have you (or anyone else...) successfully tried these products or similar on the ST7FLITE10?2004-01-09 9:34 AM
You will have to build one but Flashbash supports the FLITE10 in standalone and pc mode.
www.spen-soft.co.uk Regards sjoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
