2002-10-28 4:09 AM
ST72324 : jitter on MCO pin on PF4 set high ??!
2002-10-25 10:17 AM
I have notice some jitter on my MCO clock signal when I set high PF4
which is configured as output push pull. I have stripped down my code and I noticed that this jitter behavior is also related to PA3 state (configured as input floating low level) and CSS enabled. Have you ever got this problem on your design ?2002-10-28 4:09 AM
Your problem looks like a product limitation described in the ST72324 errata sheet. Check the October 2002 errata sheet (Rev. 5.1), paragraph 3.2.4.
Regards, JojoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
