2010-07-10 11:37 PM
ST 10 Flasher 2.4b can flash any ST10 due to the same init commands.
But it's can't dump the flash, even if the port and monitor are fine. Every thime the same:
*Dump-->ERROR
Description: LoadExternalFlashMonitor: target Not foundOnly a writing of the hex-file is possible.
Anybody knows how to start a flash dumping using this tool? Maybe it's just prohibited by ST policy and not included in that free soft...
#st10-flasher-dump2011-02-14 7:43 AM
I having the same problem. You solved it?
