2006-04-03 6:39 AM
Restart ST7 after unplugging power supply
2006-03-14 8:42 PM
Hi.
Before i used indart softec debugger and i had no problems with reset. now i am using rlink from raisonance, and what amazing is: micro does not do self-reset after power on if rlink connected to the board. Try to unplug your debugger. And read the following post, may be it will help you: http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=3719&forum=12006-03-15 3:30 AM
ok,
I'm going to look at that. But I don't know how to do only a reset. So I'm going to focus on simple reset... thanks2006-03-20 1:05 AM
I try to be clean. The reset pin is Vdd after I release reset button. With or without in-Dart, when I use reset button the micro stop but doesn't restart. So, I think that the label _stext haven't been defined. Luca, you said that stext is defined in the start up file : crts.s. I find this file in a Cosmic folder and there is a ''jump'' to main inside. But can you explain to me how the link between my file and crts.s is done ? Because I think that this file is not in micro. Thanks [ This message was edited by: Orlando on 20-03-2006 14:43 ]2006-03-20 1:27 AM
2006-03-21 3:08 AM
when I launch a debug session ... I try to find in the dissassembly window the memory address 0xFFFE and I just have the :
0xFFFD < __vectab+29 0xFFFF < __vectab+31 Could you tell why I don't have the memory address FFFE ???? A the beginning of the memory I have : 0xE000 < __stext 0xE001 < __stext+1 0xE004 < _exit main.c:29 Thanks2006-04-03 6:39 AM
Hi Orlando,
how did you programm your micro? by entering the debug session only, or by programming feature of InDART? What about oscilator, is it working after reset?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
