2015-12-17 11:10 AM
Is there any way to execute a ''pre-build command'' in STVD?
I would like to auto-increment a version number in the source-code prior to each build. I have a command-line utility that modifies a header file to do this, but I see no way to make it run at the start of the build process. Any ideas? #stvdWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
