2023-03-29 8:03 AM
2023-03-30 12:29 AM
For customised devices, i.e. components that a specific customer only has manufactured for him, a data sheet is also only available for this customer. Logically, it is not available for other customers; after discontinuation, all documents were destroyed anyway.
Now one could speculate where the Asian seller probably got these devices, but that doesn't help anyone. In any case, it is a bad idea to buy components of which you do not have the documentation beforehand.
If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
/Peter
2023-03-29 9:54 AM
It is with great regret that I have to inform you that no documentation is available for this. You should contact the respective seller, who should have information on his components - if it is a serious one.
Good luck!
/Peter
2023-03-30 12:20 AM
Thanks for your reply. The S102338002C is an semiconductor in a TO-220-7 package. It is esteemed to be a dual MOSFET component seen from the circuit in which it was found. This component is out of production and no longer available through the regular distributors. I have a suspicion that this part was custom designed in a limited production. I managed to buy a few from a chinese supplier but he can't deliver the datasheet nor do other vendors. Since the component is produced by ST, a datasheet must be available somewhere within ST. Hence my question to ST.
2023-03-30 12:29 AM
/Peter
