Others: hardware and software
Output Size in IDE (ROM & RAM Usage)
Posted on May 18, 2012 at 10:20Hi everyone,I can't find a solution to a very simple problem. STVD does not show the output size (ROM and RAM usage) when I compile with Cosmic Compiler (32K limited version). I tried many things and can see the output...
contiously reading ADC
Posted on June 22, 2015 at 17:35Hello,I have a tiny application on an STM8L051F3 (current developing hardware is a STM8L152C6), where I need to sample an analog voltage and to send that voltage every once in a while to an i2c bus. To make easy thing...
torsten2 by Associate II
  • 1079 Views
using stvp_cmdline to program st7flites5
Posted on November 03, 2014 at 03:35Hi all, I encountered few issues when using STVP to program a ST7Flites5.  Can anyone advice me on possible solutions?  Tks in advance. 1.    STVP does not provide a erase before programming option for ST7Flites5....
benedict by Associate II
  • 2043 Views
UART expample
Posted on June 14, 2015 at 22:39Hi !Until now I used mostly arduino procesors, and recenzly got one discovery board.I'm very new in programming for STM8 processors. I had searched site for expample project for UART communication, but I can't find so...
mladen by Associate II
  • 1405 Views
Reprogramming STM8S005K6
Posted on June 14, 2015 at 22:10Good evening ST Community, I am a complete newbie in microcontrollers and programming. Only advanced in Excel macro building, but not sure if that will help =D Well, also had some time spent on Arduino a few years ago...
sattarov by Associate
  • 894 Views
sdcc 3.5.0 rc1
Posted on June 11, 2015 at 18:18sdcc 3.5.0 is to be released soon. There already is release candidate 1. You can download the release candidate and have a look at it. The more eyes on it, the less likely are hidden bugs. The main changes from previo...
COSMIC LICENSE error
Posted on June 13, 2015 at 18:18I have got cosmic license file and copied it to ''license'' sub-directory of the compiler. But while compling getting error as  FlexLM System clock has been set back. I contacted to cosmic they replied as This messag...
jagspaul by Associate II
  • 1901 Views
openocd
Posted on May 22, 2015 at 18:19Hello,I try to integrate a STM8 into an existing projects build system. I need basic support to flash a controller and ideally some basic debugging support. I've managed to do this for a STM32 controller with openocd. ...
  • 1282 Views
Dubts, how to reset stm8s
Posted on December 01, 2013 at 08:05Hi guys, I am new to STM8s discovery... I have done the following code: stm8/     ;mapping.asm exists ...     segment 'rom'      start     bset $5011,#0;sets PD0 to input loop_main     ldw X,#$FFFF loop_delay    ...
lmx1 by Associate II
  • 1744 Views
