Others: hardware and software
Can assembly code running on stm8s-dicovery board?
I have tested my stm8s-discovery board for 2 days. The MCU is stm8s105c6t6, the Hex format file produced in c language on the IAR EW platform, could run as expected when uploaded into the board, but the final file from assembly language, both in Hex ...
MQi.1 by Senior II
  • 1906 Views
using swim pin as INPUT foating pin.
as per datasheet of stm8s001j3 it has been mentioned that impact of pin mode while using other pins, ex. PD1 impacts PD6,PD5... so to disable the swim pin using Out Mode Low Level, would also impact in case want to set late for PD5 as IN Mode FL NO I...
SSing.61 by Associate
  • 767 Views
STVD displays message on building the demo code from the tool itself. I am a newbie and starting with the mcu. Any ideas what and how to resolve it?
----------- Project ew - ST Assembler Linker - Configuration Debug -------------Assembling mapping.asm...asm -sym -li=Debug\mapping.lsr mapping.asm -I="C:\Program Files (x86)\STMicroelectronics\st_toolset\asm\include" -obj=Debug\mapping.objSTMicroele...
Ssank.1 by Associate
  • 1202 Views
I am not reading the address of M24M02 E2prom
Hi,I am using STM32F4-Discovery. I want to R/W M24M02 E2prom but not reading device address. Added code and datasheet. I tried AT24C256 E2prom other I2C devices by same code and it worked.Thanks. for(i=0; i<255; i++){ if(HAL_I2C_IsDeviceReady(&hi2c3...
HSE Crystal - choosing the right capacitor
Hi :) I am doing a project where I need a (relatively) accurate crystal. I have never used special precision crystals but my guess is a normal crystal would do. I would like though to have the best accuracy possible by laying out the PCB and choosing...
SLasn.1 by Senior
  • 4028 Views
