Others: hardware and software
STM8S005K6 Bootloader no responding at data
HiI have a problem when I start writing the first page of the program.I am running at 115200 8 data bit, 1 stop, no parity.I am running in ECHO mode, meaning I return all bytes from the bootloader.I have send the SYNC byte, at power up, and getting a...
HMoel.1 by Associate II
  • 1649 Views
Which antenna connection is right?
Hello,​I am currently working on custom BLE sensor for my university project and whole design is based on your ​STEVAL-BCN002V1B evaluation board. When it came to antenna routing I discovered that your schematic diagram and antenna's (ANT016008LCS244...
Please help me reverse engineer these buttons...
Hi,I am trying to figure out how a set of buttons interfaces with the microprocessor - an STM8S 003K3T6C ([url=https://www.st.com/resource/en/datasheet/stm8s003f3.pdf]datasheet[/url])I am familiar with simple button config - you pull GPIOs high or lo...
Rjohn.1 by Associate II
  • 3003 Views
STUSB4500_GUI cannot detect NUCLEO board
I am using a NUCLEO-F072RB with a STEVAL-ISC005V1 dev board. The STUSB4500_GUI is v1.11. The Nucleo firmware is V2J37M26. Windows 10. The NUCLEO board shows up as a COM port and as ST-LINK in the device manager.Running HwCheckUtility sees the COM...
WFord.1 by Associate
  • 1265 Views
Hi, My Onkyo receiver got frozen and behaving stubborn. Can I program M95640WP using CH341A Programmer any help in this matter shall be highly appreciated. datasheet included here https://ibb.co/1JTWkLs thanks in advance Modify message
Hi,My Onkyo receiver got frozen and behaving stubborn.Can I program M95640WP using CH341A Programmerany help in this matter shall be highly appreciated.datasheet included herethanks in advance
Pbhat.1 by Associate
  • 1560 Views
STM32F4xx and ESP8266 with SPI
Hello everyone i'm new here,My problem is i want to work with ESP8266 wifi module (mine is Adafruit HUZZAH ESP8266 i will share a link aswell...) via SPI protocol. I did some research and i couldn't fine any library/drivers or example about this. Th...
