Others: hardware and software
The idea of a chip with pins in the form of a plug.
The big problem is the microcontroller pins, which often break and make the chip unusable.My idea is to use the terminals of the microcontroller as a plug, on which you can immediately put the socket on and attach the microcontroller with screws. In ...
ssm by Associate II
  • 2001 Views
Chip idea
Future time requires minimizing the cost of chemical elements. In addition, robotics is gaining power. Your chips will improve. It will be necessary to reduce the nodes, microcircuits and their functions. The work of microcontrollers in closed contai...
ssm by Associate II
  • 2251 Views
M95M04-DR Instruction commands
Page 6 of the datasheet for the M95M04-DR EEPROM has the commands for RDID/RDLS and WRID/LID listed as the same exact commands.Can someone please post the correct command set for this part.
MHami.4 by Associate
  • 1207 Views
STEVAL-ISA164v1 not correctly responding
I've got a new STEVAL-ISA164V1 Board.The problem looks like this:When connecting with the ST SMED Configurator there is a warning:The chip on my board is double checked a STNRG388A (well that's what is printed on the chip)I can connect and it looks l...
pbaum.1 by Associate II
  • 1515 Views
Can anyone provide me the spice model of an obsolete (not so obsolete as I purchased it in 2019 December) diode with the model number STPSC1206D?
I even tried to find the model (STPSC1206D) on your new rectifier simulator with the following URL:https://eds.st.com/schottkyferd/Even though as per STM the mentioned part number is obsolete I need the spice model as it is a significant part of my P...
AKuma.39 by Associate
  • 1597 Views
About operating voltage of ST_M24512-r.
We would like to confirm questions below.ST_M24512-r1. Do you have datasheet for information about SCL speed and minimum Vcc? 2. Is our understand correct that the minimum Vcc of ST_M24512-r is 1.8V with our using SCL 400 khz ?      3. Related no.2. ...
TKron.1 by Associate
  • 1484 Views
