Others: hardware and software
Resolved! About TIM2 in compare mode: I have a few questions about what happens to the output when the timer counter overflows
1. What happens if TIM2_ARR is 0xFFFF? Does overflow occur when timer counter counts past 0xFFFF?2. What happens to compare output after TIM2 overflows? For example, lets say that the TIM2_CCR1 = 0x7FFF so the output changes state when the counter co...
AMacd.1 by Senior
  • 1689 Views
Hi, We have found part VN750SMPTR-E which is almost pin to pin compatible with VN750PS-E . Except 4th Pin. 4th Pin in VN750PS-E is - NC 4th Pin in VN750SMPTR-E is - STAT_DIS What is the use of the Pin STAT_DIS. Shall i left this pin as NC.
Hi,We have found part VN750SMPTR-E which is almost pin to pin compatible with VN750PS-E . Except 4th Pin.4th Pin in VN750PS-E is - NC4th Pin in VN750SMPTR-E is - STAT_DISWhat is the use of the Pin STAT_DIS. Shall i left this pin as NC.Regards,Suriya
Suriya R by Associate II
  • 732 Views
