2021-12-27 2:31 AM
2021-12-30 12:06 AM
Maybe you can get the VN750SMP-E, which is almost pin2pin compatible (only pin 8 pin 4 differs).
Good luck
/Peter
2021-12-30 9:17 PM
Hi Peter,
Thanks for the reply.
unfortunately suggested part also currently not available.
Regards,
Suriya R
2021-12-31 12:12 PM
Most places seem to suggest these are VN750PS-E obsolete, you only real path would be brokers, and doing whatever lifetime buy you're going to need
https://octopart.com/search?q=VN750PS-E¤cy=USD&specs=0
Probably time to redesign
2022-04-22 1:03 AM
We have found part VN750SMPTR-E which is almost pin to pin compatible with VN750PS-E . Except 4th Pin.
4th Pin in VN750PS-E is - NC
4th Pin in VN750SMPTR-E is - STAT_DIS
What is the use of the Pin STAT_DIS. Shall i left this pin as NC.
Regards,
Suriya
