2020-11-24 8:06 AM
Electronic designers can leverage worldwide “maker�? trend and use off-the-shelf easy-use platforms like Raspberry Pi for IoT demos or for evaluation purposes - at least as a starting point before you select a suitable component and eva board, tools, etc. In particular, you can enable I2C bus and perform simple transactions in short term - even with no prior RasPi experience. If you are interested in my experience, see follow this link for further info: http://www.chip-info.com/articles/iot-raspberry-pi/
Take care,
Kersten
2020-11-25 3:21 AM
Hi @Kersten ,
it's an interesting article, thank you for sharing the knowledge!
I think it can be a useful solution for using ST sensors (also motion, and not only environmental ones) in conjunction with Raspberry Pi starting from zero in an IoT perspective.
-Eleon
