Tilt angle sensor
Central SUPPORT
Senior II
We are looking for a sensor that can identify tilt angle with respect to gravity. I have been looking around at 3-axis accelerometers but cannot be sure if these will work as a tilt angle sensor. Please advise.
NOTE: This question and answer originated from a customer support case which was handled by us. We regularly review support cases and add any helpful ones here for all to benefit from.
1 ACCEPTED SOLUTION
Accepted Solutions
Central SUPPORT
Senior II
Yes, you can use many of our LIS2 and LIS3 devices for this purpose, see more info here https://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html
There you will find an application note AN4509 (also attached here) describing “tilt sensing theory and the methods of determining tilt angle measurement of a low-g 3-axis accelerometer�?. This will certainly help.
2 REPLIES 2
Central SUPPORT
Senior II
AvaTar
Lead
With a 3-axis accelerometer and a bit of vector calculus, no problem.
Part of INS solutions, many with freely available sources.
