2022-09-26 7:37 PM
I am use lsm6dso with NUCLEO—F401RE board. I want to know what are the roll pitch yaw sequence of calculation. We can not transform body frame to naviagtion if we don't know the transformation matrix sequence.
2022-09-30 8:21 AM
Hi @HLAW.1 ,
You can refer to DT0060 Design tip to calculate quaternions or Euler's angles.
If you are using an ST library such as the one in the X-CUBE-MEMS1 FW package, you can consider the MotionFX sensor fusion library, which provides real-time motion-sensor data fusion. It also performs gyroscope bias and magnetometer hard iron calibration.
-Eleon
