LIS2DE12 and a buzzer on board
Hi, folks,I'm using LIS2DE12 on the PCB. The purpose: the device should inform the firmware, if the PCB has moved - intruder detection. I successfully programmed the device for INT1 on 6D movement. It works fine in general.On the PCB I have also a sm...
Resolved! How to get yaw angle from IMU 10 dof (GY-86 MPU 6050 and HMC5883l)
I have the imu 10dof and i got raw data of accelerometer, gyroscope and magnetic. And i calculate the roll, pitch, yaw base on equation same in picture. i had calibrate accelerometer and magnetic. in the picture, show the data of magnetic before and ...
KNguy.11 by Associate
  • 3572 Views
LSM303C Click event setup
LSM303DLH has CLICK register to setup it but LSM303C has only commont THS and DUR registers set, can I use it to detect single tap event? As I understand I can setup AND config for all axis, but it doesnt work so good and I can get false detection fo...
Resolved! ST-EVALMKI212V1 not recognized on ST-EVAL109V3 ?
Dear ST Community,Ten days ago I already asked this support request but no one single response came from ST.I just bought and received an ST-EVALMKI109V3 + ST-EVAL212V1 after attending the webinar "Develop effective AI solutions for monitoring vehic...
tlamotte9 by Associate II
  • 4080 Views
Resolved! LIS2DW12 reserved pin functionality
Hi,I am debugging my custom board where I soldered an LIS2DW12 accelerometer on it. I forgot to pull the reserved pin ( 7 ) to ground as suggested in the datasheet. This is how I connected it:This is how it should be connected:Is this required, that ...
CMoeb.1 by Associate
  • 1433 Views
How to convert G to dbVrms
Hello Team,We would like to measure the vibration using LIS2DW12 (3-axis MEMS accelerometer), from the LIS2DW12 we were getting units in 'g' or 'mg'.Please let us know the possibility of converting g to dbVrms.Best regards,Abishek Devan
