2020-01-02 1:59 PM
I have a SensorTIle package. I tried to run the Vibration Monitor Example but it says "SD file for Vibration Module not found. How do I get this file so I can test said component?
2020-01-03 1:29 AM
Hi @WVarn.1 , you can try to generate a Vibration SD file launching the example app Vibration monitoring - Training. If it still doesn't work, you can contact the local support that will provide you the appropriate file to be compared by Vibration app example. Regards
